Removing Valve Covers
Both driver and passenger side valve covers are leaking oil. While physically removing the valve covers and installing a new gasket is very simple. I'm concerned about getting clearance to remove & install them. It looks like I need to remove the air intake, upper intake manifold, crankcase vent tube, PCV valve and spark plug wires to get clearance and access to the bolts. Correct? There are a couple of metal tubes that are in the way too. Do they need to be removed or are the flexible enough that I can just move them out of the way during removal & install? Is there anything else I need to remove? Anything I should keep an eye out for? Any tips?
Thanks in advance...
Welp you can try to remove them without removing the upper intake but its really not that big of a deal to remove it.
When I had problems with my lower intake manifold gaskets on the 00' splitport I was able to take it apart, clean it, put the gaskets back on and torque it down to spec in just a handful of minutes.
A singleport is a little easier.
If you do this then grab an upper intake manifold gasket and EGR gasket too, that should be it as far as other gaskets that you would need.
LivingInThePast
Sep 16, 2015 12:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
