Suspension help
i want to completely redo my whole suspension, but right now i wanna lower it im tried of how high it sits. i've already found some springs i want to install but my question is what eles do i have to upgrade so that way it doesnt mess any thing up, meaning like CC plates ect.... ?
thanks
thanks
Your stock shocks/struts will wear out faster so you'll want to upgrade those. Any lower than 1.5 inches generally you'll need cc plates. You can get away without them if you want. Instead of spending over $800 for some decent springs,shocks,and cc plates you might want to look at a coil-over system. Or get it done cheap, find some roush springs. They will give you about a .75 inch drop so it will look better but you won't need cc plates and your shocks/struts should last longer because its not that low and they were designed to work with stock suspension.
OP... you could also go with C rated spring by Ford. It'll drop you an inch around. CC plates aren't need for them as well and the set is only $169 new. Im not sure though how they compare to Roush. I know they a bit less expensive. (Roush your paying mostly for the name) lol
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
