Need help with airbag problem...
Hi guys, this is my first post and I need some help.
I bought a 2000 Mustang v6 that was in a front end collision and both air bags deployed. I had the air bag module reset and purchased 'new' airbags.
This is my problem. When I plug in only one airbag, either the right side only, or the left side only, I get a airbag error for the side that's not plugged in as being 'open' - well that makes sense, nothings plugged in for the corresponding airbag.
When I have both airbags plugged in I get code 35; passenger airbag circuit shorted. But like I said above, if I leave the passenger airbag plugged in, and remove the drivers, I will get code 32; drivers open, and it would appear that the passenger is fine.
I also plugged the drivers airbag into the passenger airbag connection and vice versa, but same problem; which leads me to believe that the airbags themselves are fine.
What should I try now? I believe my clock spring to be fine and am out of ideas. I have a Hyans manual, but it does not have any sort of airbag troubleshooting or wiring diagrams.
Any help would be much appreciated.
in our car i THINK it's the style sensor that once it's triggered it done and has to be replaced because it's two contacts separated by insulation and in a crash the contacts break and come in contact and stay
Is that the sensor on the bumper that your talking about(believe it to be the G-sensor), or the one in the dash(airbag control module)?
