Please help! Starting issue...
Old Aug 6, 2005 | 07:57 PM
johngyver's Avatar
johngyver
Default Please help! Starting issue...
To anyone who can help me...
I have a 2000 v6 mustang that will crank but will not start. Here is what I have tried;
* No security system issues found - Car cranks, no start.
* Installed new coil pack - left battery terminals off for two hours to reset computer.
* Check fuel cut off switch - seems to be fine.
* No fuses out, all seem to have power through them.
The mustang cranks strong. It does not start. I know that it is usually fuel or spark related however I have tried the basics without success. Thank you for any suggestions! have an awesome day!
John Gyver
Old Aug 6, 2005 | 11:31 PM
ckthecerealkiller's Avatar
ckthecerealkiller
Default RE: Please help! Starting issue...
Have you checked the starter, spark plugs, the ignition wires, fuel pump, do you get a good voltage readout when you turn it to the on position, there are a million and one different things it could be.
I am a little tipsy right now so I am not thinking straight.
I'll post again later, enen though I am not the greatest thing in the world when it comes to starting issues.
You might also want to try the General tech forum. This isn't necessarily v6 related. Starting problems are very general.
Old Aug 7, 2005 | 12:19 AM
I_spin_out2much's Avatar
I_spin_out2much
Take it to a mechanic and they have a computer that will point you right to your problem soo i would sugest doing that befor you wast any more money on parts you may not need .... good luck
Old Aug 7, 2005 | 04:47 AM
02StanGT's Avatar
02StanGT
ORIGINAL: ckthecerealkiller
I am a little high right now so I am not thinking straight.
I'll post again later, cause I am the greatest thing in the world when it comes to starting issues.
You might also want to try the General tech forum. This isn't necessarily v6 related. Starting problems are very rare.
He said the motor cranks strong. Anyways, you using the same key as always? I know if you get a key made and it wasn't made from the dealership, and try it on your car it won't start due to the chip in the key.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
dalefrancis88
Sep 11, 2015 07:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
