Adding Acetone in Fuel?!?!
Old Aug 29, 2010 | 01:23 AM
neo8222's Avatar
neo8222
Originally Posted by crysalis_01
The facts are it WILL eat some fuel system components, and yeah you MIGHT see a slight mpg increase. . . but is it worth it? I'd say no.
what do you mean the "facts are" no one has proven or disproven that a proper mixture of acetone can cause damage. yes on SOME parts a high concentration of acetone will cause damage but a ratio no higher than 1:320 should not cause damage anymore than gasoline would. gasoline and acetone are both hydrocarbon solvents, from what i've read the only people that have problems are the people that have put to high a concentration into the gas. if you want to go that route think about this as well. seafoam which most everyone on this forums use will cause damage if you pour 3 cans into a 1/2 tank of gas. but when used in the right mixture ratio is perfectly fine and helps the car.
Old Aug 29, 2010 | 09:27 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
I got a bottle of good old fashioned snake oil that will do wonders for your car
Old Aug 30, 2010 | 04:34 PM
neo8222's Avatar
neo8222
will it make my car corner better too??
Old Aug 31, 2010 | 08:21 PM
03shadow's Avatar
03shadow
sign me up if it does
Old Aug 31, 2010 | 10:59 PM
RyansQuick6
Reverse Gear Member
When properly used, the improvements are limitless
Old Sep 1, 2010 | 01:26 AM
Snakebite64's Avatar
Snakebite64
Good land for sale north of the Artic Circle oh and cheap to
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
Oct 5, 2015 07:40 AM
mungodrums
Sep 28, 2015 10:54 PM
mrappe
Sep 26, 2015 10:16 AM
