Help with mods!!
Old Dec 25, 2010 | 01:45 AM
  #31
B4TM4N's Avatar
B4TM4N
I am not the most wire savvy person i know, but i were willing to purchase this to be installed into my car, how much am i looking at?
and also, I have decided to go with the smoked headlights for my car, my only worry is that
A) the lights will not be bright enough
B)problems with fogging and water etc.
any advice?
-B4TM4N
Old Dec 25, 2010 | 03:30 AM
  #32
Fink's Avatar
Fink
before you put new headlight housings in, seal them up. Run a bead of silicone around the part where the clear plastic meets the dark plastic, you may need to do this a couple times but if done with enough patience it can work the first time. I sealed mine up, but i need to redo it.
Then get a set of Silverstar Ultra's. To me, I see just as good with smoked+ultra's than I did with stock headlights and regular halogens.
If you want me to, I can sketch you up a diagram of how I wired my foglights in. It is amazingly simple.
Old Dec 25, 2010 | 07:44 AM
  #33
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Get some hid's and the tint won't be an issue
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
firecoyote
Sep 27, 2015 02:37 PM
