O2 Sensor question
Old Feb 19, 2011 | 01:52 PM
WoahPony's Avatar
WoahPony
Default O2 Sensor question
I need to install my rear o2 sensors this weekend on the 6'er and was wondering what the difference is between the rear o2's and fronts... The sensor looks exactly the same, the wiring is the same, and it has the same 4 pin connector. the only difference is the 2 small plastic pieces on the male connector that stop it from fitting into the female rear connector... Just saying. because I need to either buy a new rear o2 sensor... OR I could just pull one of the front o2 sensors off the 97 engine I have and snip those two thin plastic stubs. Would this work?
Old Feb 19, 2011 | 03:53 PM
NewEdgeStang00's Avatar
NewEdgeStang00
I would go ahead and buy a new sensor for the rear, just so it matches up and it'll be fresh anyways. It shouldn't be much I went ahead and put in a motorcraft o2 sensor for $6 from advanced auto
Old Feb 19, 2011 | 04:32 PM
WoahPony's Avatar
WoahPony
6 dollars for an 02 sensor???? really?
Old Feb 19, 2011 | 05:09 PM
v6stang07's Avatar
v6stang07
yea just buy a new one and without the clips it might come loose
Old Feb 19, 2011 | 05:38 PM
PDOT2one's Avatar
PDOT2one
I would spend the couple bucks, that way you know its right and if youremove the clip vibration could make it fall off.
Old Feb 19, 2011 | 06:07 PM
NewEdgeStang00
yeah it's cheap lol no biggie. It was either $6.38 or $3.28, one of those prices. But I definitely remember no higher than $6.
Old Feb 19, 2011 | 07:16 PM
WoahPony's Avatar
WoahPony
I find it very hard to believe that an O2 sensor is under 50 dollars. and about the clips, the clip is still there, there are just two small pieces of palstic that make it match up to the female connector. it will still be held in place...
Old Feb 19, 2011 | 09:22 PM
NewEdgeStang00
Yeah its cheap, just go by advanced auto sometime they should have them stocked up.
Old Feb 21, 2011 | 01:47 PM
my01pos's Avatar
my01pos
I have been pricing o2 sensors the cheapest one i have found is at o'riellys for around 45 bucks, its a bosch brand.
Old Feb 21, 2011 | 02:18 PM
ESG-642T's Avatar
ESG-642T
Buyer Beware
Yeah good luck finding an 02 sensor that cheap!
