a lil help
Old Apr 13, 2011 | 02:27 PM
skibum1106's Avatar
skibum1106
Default a lil help
I just bought a 1997 stang for a project car, and I was wondering if you guys cna give me a hand with a small issue. When driving the car the steering wheel shakes and when i make turns it shakes even more. I was thinking that it could be either that wheels need to be balanced or new rotors. Do you gusy have any other input in this matter?
Old Apr 13, 2011 | 03:02 PM
compdude97's Avatar
compdude97
Wheels, Alignment, flat spot on the tires, if it was the rotors it shouldn't be as noticeable (if at all) when not on the brake.
Was this car sitting for a while? if it was my guess would be the tires.
Old Apr 13, 2011 | 03:52 PM
skibum1106's Avatar
skibum1106
it was sitting for a few months the previous owner said, the tires do need to me swapped out and im planning on donig that, im hoping thats it. you dont think it could be the axel?
Old Apr 13, 2011 | 04:32 PM
Daehawk's Avatar
Daehawk
Idler arm id my guess. Least that was it on my old Toyota.
Old Apr 13, 2011 | 11:17 PM
NeoTokyo's Avatar
NeoTokyo
Not Applicable my friend.
Old Apr 13, 2011 | 11:18 PM
NeoTokyo's Avatar
NeoTokyo
btw, sounds like a bad inner tie rod end for the turn and bad outter for the vibration.
Bad bushings will also give you bad vibrations, they are rubber and on a 97' they are probably bad, cracked and compressed by now.
I suggest getting a master front end kit and new end links and maybe even a rebuilt power rack or a low mile one just to freshen up the whole front end.
Some new struts will also do you good, low mile used Mach 1 Tokico's are good as well as 03/04 Bilsteins if you want to stay cheap.
Otherwise you can get Tokico blues or Koni streets to stay on a budget.
Old Apr 14, 2011 | 09:30 AM
compdude97's Avatar
compdude97
It really could be about 100 different things. I didn't even thing about the bushings but that is a possibility. I would start with the tires, and an alignment. If there is anything wrong with ball joints or tie rods they should tell you at the alignment shop, but given the age it may not be a bad idea to replace them regardless, which being a project car I am sure that is on your list.
jaiidutch
Sep 14, 2015 10:29 AM
MustangCavron66
Jul 8, 2004 04:34 PM
SHESA64
Apr 30, 2004 03:22 PM
sc351W
Mar 19, 2004 02:47 PM
