cant downshift from 5th
Old May 13, 2011 | 08:51 PM
cmfrossman's Avatar
cmfrossman
Unhappy cant downshift from 5th
i have a 99 v6 mustang, i can shift all gears up and down but if i go into 5th i cant take it out and down shift. i have to come to a complete stop and shift. does anyone know what could cause this to happen?
Old May 16, 2011 | 08:06 AM
NeoTokyo's Avatar
NeoTokyo
Welcome to MF.
Does it grind when going into 5th or is it hard to pull it into 5th?
Old May 16, 2011 | 10:47 AM
94v6's Avatar
94v6
I had similar problems with a previous car (not a mustang). Eventually I couldn't even get into 5th gear. I ended up having to replace the transmission
Old May 17, 2011 | 08:46 AM
cmfrossman's Avatar
cmfrossman
Unhappy grind
no, it does not grind at all. i can put it in 5th just fine and when i take it out >to neutral> it doesnt shift, just stays in 5th gear. i can move the shifter anywhere ( i.e.1st gear) and its still in 5th. the only way to correct it is to stop, shut the car off, and put it in reverse, then start it again.
Old May 17, 2011 | 10:36 AM
3.0Taurass's Avatar
3.0Taurass
Shift linkage?
Old May 17, 2011 | 04:42 PM
NeoTokyo's Avatar
NeoTokyo
Hmmm, I am not a transmission expert but it could be a bad synchro or bad gear fork but it seems more like a really bad synchro because you can take it out of gear once the car is stopped and the engine is off.
Old May 18, 2011 | 10:32 AM
cmfrossman's Avatar
cmfrossman
i will check all of that and post back if i find a problem.
Bokeo
Oct 10, 2015 08:28 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
guitarman376
Sep 30, 2015 05:54 PM
foxdude
Sep 24, 2015 08:45 PM
TheDutchTexan
Mustang Videos
Sep 10, 2015 06:51 PM
