Hestitation
Old May 14, 2011 | 11:35 PM
pslake1's Avatar
pslake1
Default Hestitation
I have a 2002 V6 Mustang. If I accelerate har, especially on the highway I get a hesitation. I took it in and had codes read and it said low fuel pressure. I replaced the filter and then the fuel pump with no change. Any ideas?
Old May 16, 2011 | 09:22 PM
Ravenkil's Avatar
Ravenkil
check the fuel pressure at the shrader valve on the fuel rail.
Old May 17, 2011 | 09:06 AM
94v6's Avatar
94v6
Possibly the fuel regulator? What are you getting for pressure?
Old May 17, 2011 | 09:38 AM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
FPR is electronic on new edges, and its a returnless system. Check you IAC or MAF, they may need to be cleaned.
Old May 18, 2011 | 11:42 AM
Ravenkil's Avatar
Ravenkil
Could a bad TPS also cause this?
Old May 18, 2011 | 06:26 PM
pslake1's Avatar
pslake1
Thanks for All the comments IT would be nice if You All would dumb it Down a Bit .
Old May 18, 2011 | 06:43 PM
RyansQuick6
Reverse Gear Member
Iac = idle air control. Its on the throttle body
Maf= mass air flow sensor, on the intake tube behind the filer
Old May 18, 2011 | 06:45 PM
RyansQuick6
Reverse Gear Member
Use orielly's brand brake cleaner to clean them, make sure you remove the maf before cleaning it, and get a new gasket for the iac
Old Jun 24, 2011 | 02:57 PM
MustangFaith's Avatar
MustangFaith
the EGR valve, the hoses for the emissions system, or the throttle position sensor...? I am having the same issue... Changed the hoses, that helped a little, EGR and throttle are going in tonight. Also, check to see if you MAF sensor is clean...
ChiDiddy
Oct 29, 2012 11:21 PM
jj01gt
Sep 25, 2012 06:54 AM
KiTTyGT
Feb 13, 2012 03:11 PM
mjay2020
Feb 13, 2011 05:48 PM
palerider
May 26, 2006 02:41 PM
