A/C Problems
Old Aug 31, 2005 | 05:40 AM
Trustfall990's Avatar
Trustfall990
Default A/C Problems
Recently I took it in for an oil change. The A/C hadn't been working correctly before the change (Cold air was only blowing from the defrost vents) and after the change the cold air blew out of the normal vents. It worked only for a couple of minutes then started to blow out of the defrost vents again. Someone said it might be the vaccum hose but I don't know where they are. Could someone tell me so I can check it out?
Old Aug 31, 2005 | 06:12 AM
02StanGT's Avatar
02StanGT
Default RE: A/C Problems
I don't know if it's the same on v6's, but on my GT it is a red tube that connects just downstream of the throttle body. The tube has a small diameter. If I saw a picture of your engine bay I could probably point it out to ya.
Old Sep 1, 2005 | 08:18 PM
dbaisley's Avatar
dbaisley
the same thing happened to my 98 stang and it has been killing for a like 2 years nowwhere can i get it fixed and is it something i can do
vargas
Jun 17, 2017 12:17 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
SteelerNation82
Sep 16, 2015 07:11 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
