AC related issues
My AC started blowing stale air a couple of weeks ago. So my buddy took it to work (He works at a dealership) and the tech, installed or added free-on and was working right for about like 12 hrs. Now my car blows stale air again, and out of nowhere my temp gauge stays just a tad bit over the C mark. Not sure it any problem has any correlations.???
that's what i was thinking. is there any way to tell it's the compressor? also would it affect the coolant temp?? im kinda lost on that one.
I don't think it would affect the coolant temp but anything can happen. It didn't mess with mine when mine went out. I believe there is a way to check but not sure if this is the right way; turn your car on and also the AC then look at the compressor to see if it is spinning.
Now that I think of it that sounds dumb though cause wouldn't it spin regardless since it is on the belt?
^^ here is a topic on another forum that basically says just watch the compressor to see if it turns over or not. Hope this helps, it is all I really found on google.
HTML Code:
http://www.allfordmustangs.com/forums/v6-tech/112179-1997-mustang-how-can-i-tell-if-my-c-needs-charging-replacement.html
Could be compressor, but usually it ends up being a crack in one of the lines allowing freon to escape. I'd go pop the hook at look for a crack - especially at the joints of the piping.
If you have a coolant temp issue, the only way it could be related to the AC is if you have a bad belt... and both the AC compressor and the water pump aren't turning over correctly.
