Transmission Problem?
Old Jan 5, 2012 | 02:10 PM
V6Stang93's Avatar
V6Stang93
Default Transmission Problem?
Ok guys, this is just something I've been noticing over the last six months. Whenever I'm in 4th gear in the higher RPM's, say around 3500 and up, and go to shift into 5th gear, It grinds and doesn't catch. I really have to force it in order to get in 5th. Now, this isn't all the time that this occurs, but i have been noticing it more often recently. Cold weather related? Any ideas? oh I have an 01 V6 5 speed with 101,000 miles on it. Thanks for your help!
Old Jan 5, 2012 | 04:47 PM
Daehawk's Avatar
Daehawk
Sounds like a clutch problem.
Old Jan 5, 2012 | 04:51 PM
3.0Taurass's Avatar
3.0Taurass
Synhros maybe? Try letting the rpms drop more before trying to shift. If you're not having any problems with other gears I don't think it'd be a clutch issue
Old Jan 6, 2012 | 03:20 PM
shipwreck_98's Avatar
shipwreck_98
Readjust the clutch cable, if that doesnt help, it is the fifth synchros.
Old Jan 6, 2012 | 05:30 PM
Chromeshadow's Avatar
Chromeshadow
Have you ever changed the trans Oil?
Old Jan 6, 2012 | 06:48 PM
V6Stang93's Avatar
V6Stang93
No I have never changed the trans oil myself. I bought this car used at 92,000 miles. It had 2 previous owners so I'm not sure if they did or not, but I'd be willing to beat it hasn't been changed. I did put on an aftermarket clutch quadrant, cable, and firewall adjuster. Maybe I have it too tight? Oh and to 3.0 yea if I let the rpm's die it shifts in like normal.
Old Jan 9, 2012 | 04:17 PM
V6Stang93's Avatar
V6Stang93
ok so I experienced something new today. While I was in 5th gear it acted like the clutch was slipping, but when I was in any other gear it acted like normal.
04stangman
Sep 26, 2015 09:33 AM
showoffzx2
4 Cylinder NA and Turbo
Sep 14, 2015 08:40 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
vintageaion
Sep 8, 2015 10:45 AM
