NOT your common P0301
Old 02-07-2012, 07:50 PM
Jackman5003
Jackman5003's Avatar
Default NOT your common P0301
2000 Mustang 3.8L Automatic
DEAD miss on cylinder one according too the P0301 code, Cylinder contribution test on the snap on scanner is -22 or so, and pull the plug on injector 1 too have no tone change, hence, cylinder one is DEAD!!! Not occasional miss, its a nice, rythmic, shake of a dropped out cylinder.
Spark is good, checked plug to have it look fine and just like cylinder 4's. Used a spark tester, its good and blue. Flipped number 5 and 1 wires, still miss.
Fuel is good, Noid light lights up great, fuel injection service did nothing, swapped used injector into cylinder 1, still miss's
Compression at 148, 150, while cylinder four is 149, 150
Leak down is less then 7%
Vaccum gauge steady
Pulled plenum and valve covers tonight, springs are fine. Only thing i did notice is that cylinder 1, when not under tension, the rockers are loose, as in, can move them side too side. Cylinder 4 has the same issue with the intake rocker. Is that normal lifter bleed down? If so, why not the other lifters bled out too? The holddown bolt is tight.
Come on now, dont tell me that all this carbon buildup inside this intake (1/4" thick in some spots) is causing this miss...WHAT THE HECK IS IT?!
Jackman5003 is offline
Old 02-13-2012, 11:41 AM
Jackman5003
Well thanks for no response there mustangforums....
It was the lifters. They were quiet, but slightly collapsed. All new ones from rockauto, let the upper and lower intakes soak overnight in the parts washer, and then seafoamed the intake when it was running again. Runs great now...
Old 02-14-2012, 08:16 PM
slonison
slonison's Avatar
Hey man!
5 Days isn't that much time for someone to give much of a response but hell I can see you're a good guy because you found the solution and came back with it. Much appreciated!
slonison is offline
Old 02-15-2012, 07:45 AM
Jackman5003
Try going over too v8s10.org and see how many responses i got there. And thats a much more specific group then a mustang forum. Haha
CS2007
06-25-2019 09:45 PM
9550
10-26-2015 05:01 PM
zanemoseley
09-06-2015 12:58 PM
Quick Reply: NOT your common P0301
