Performance Chip?
Old Mar 24, 2012 | 04:04 PM
  #31
mustangman02232's Avatar
mustangman02232
Originally Posted by BabyGT
Looks decent if not to much bigger BUT, big but here, the traction control will flip out cause it senses the front spinning faster and thinks it has lost control and you won't be able to move because the traction control will kick in full blast, you need a tuner to turn off the traction control before you do that.
traction control uses the ABS sensor on the rear wheels and measures side to side spinning....
Old Mar 24, 2012 | 04:09 PM
  #32
BabyGT's Avatar
BabyGT
No it measures wheel speed in relation to the rest of the wheels
Old Mar 24, 2012 | 06:31 PM
  #33
jthorn9's Avatar
jthorn9
The Godfather
Actually traction control uses the ABS sensors to detect loss of grib and applies breaking friction to spinning wheels with lessened traction to increase traction, control, and stability.
Old Mar 25, 2012 | 03:01 PM
  #34
thayes1's Avatar
thayes1
I've actually decided against it. My dad told me that he knows people with it like that and since you can't rotate the tires, you gotta swap and get new ones almost every 10k miles. And driving back and forth to college every couple weeks, that'll just burn money.
Old Mar 25, 2012 | 03:14 PM
  #35
mustangman02232
unless your constantly doing hundred foot burn outs there is no way you would get only 10k out of a decent ROAD tire (does NOT include DRs)
Old Mar 25, 2012 | 03:28 PM
  #36
jthorn9's Avatar
jthorn9
The Godfather
I've always gotten between 30,000 to 40,000 miles out of my tires, then again I get all the same size wheels/tires so I can rotate them.
Old Mar 25, 2012 | 03:37 PM
  #37
ESG-642T's Avatar
ESG-642T
Buyer Beware
I think I'm lucky to get 15k out of any of mine
Old Mar 25, 2012 | 03:41 PM
  #38
jthorn9's Avatar
jthorn9
The Godfather
Sheesh!!! What kind you use lol
Old Mar 25, 2012 | 03:42 PM
  #39
ESG-642T's Avatar
ESG-642T
Buyer Beware
Everything I own has a DR on the rear
I used to (when i was like 22) drive around on ET/streets :P
Old Mar 25, 2012 | 04:06 PM
  #40
jthorn9's Avatar
jthorn9
The Godfather
Sheesh, I drive way too much to use anything like that. My tires are limited to high performance all year tires.
