engine dies while driving
Old Aug 22, 2012 | 04:27 PM
Jaystrucks2's Avatar
Jaystrucks2
Default engine dies while driving
Just bought a 1998 Mustang 3.8 auto. Seller told me it dies while driving.
Took it back home about 50 miles. No problem except once after about 25 minutes of 65 mph driving, I saw the tach jump from 1500 to 3000 rpm. Engine did not ref up.
When I was pulling off the interstate, the tack again went to 3000 rpm. This time the engine bogged and the yellow check engine light flashed. I slowed down and kept it going till I reached home. Any ideas where I should start.
It has 186K on miles but looks like its in pretty good shape.
Thanks!
Old Aug 22, 2012 | 05:16 PM
FrostByte's Avatar
FrostByte
Check for codes.
Old Aug 24, 2012 | 03:44 PM
Jaystrucks2
The only code that shows up is P1729 4x4 low switch error, which doesnt make sense.
Cleared the code and went on a 20minute drive with the OBD reader plugger in. Again when coming off a ramp and excellerating it liked shifted into neutral, tach went to 3000.
Then traany caught, engine bogged down and check engine lite flashed, but no codes were registered on the reader.
Old Aug 25, 2012 | 02:15 PM
Fryguy22's Avatar
Fryguy22
Swap out the IAC valve and the PCV valve. The IAC valve is most likely the culprit but it usually gets gunked up due to a poor performing PCV valve. Swapping out both should solve your problem.
Old Aug 27, 2012 | 02:17 PM
Jaystrucks2
Thanks Fryguy. I've ordered an IAC. Will make the change over the weekend.
Old Sep 4, 2012 | 08:36 PM
Fryguy22's Avatar
Fryguy22
Curious if you put in the new IAC yet?
Old Sep 5, 2012 | 05:12 AM
Jaystrucks2
Not yet, purchased one from AutoZone. hope to install this weekend.
I'll let you know if it works.
Thanks for your help.
Old Sep 5, 2012 | 07:26 AM
uberstang1's Avatar
uberstang1
Chupacabra
Moving this tot he v6 section.
Old Sep 9, 2012 | 02:45 PM
Jaystrucks2
Default Engine dies
While doing the engine antifreeze flush(mostly rusty water), I did a compression check on the cooling system. A large leak at the intake manifold. Before I replace the IAC valve I'm going to replace gasket. Thanks.
Old Oct 22, 2012 | 05:19 PM
Jaystrucks2
Replaced both intake manifold gaskets, found back two water ports blocked with mud (radiator sealer). Replaced spark plugs and wires. Engine runs good now. Next brakes and rotors.
jpplaw
Mar 19, 2025 08:53 AM
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
Gary Ugarek
63
Dec 11, 2015 02:01 PM
HIS S-197
Aug 10, 2015 05:47 PM
