Rear bearings/diff problem?
Old Mar 9, 2013 | 06:27 PM
tmkf_patryk's Avatar
tmkf_patryk
Default Rear bearings/diff problem?
So I have this mustang here that I recently bought, did some work on it and took it for a drive. It was making like a grinding/rubbing type of noise. In neutral without moving theres no noise, even revving the engine. So I lifted the rear end up and when in gear, it would make noise as the tires spin. Possibly rear bearings?
Well, I took out the rear brakes and have the wheel fastened to the rotor/hub and now I can pull and push the wheel a tiny bit from both sides, but enough to hear and see it being pushed in and out. Does not seem normal.
If it was the bearings, wouldn't I have a puddle under the rear diff? (if bearing gone, the seal would probably go aswell I would think)
Thanks!
Old Mar 9, 2013 | 11:10 PM
joey2000srs's Avatar
joey2000srs
It might be the pinion bearings. When i first picked up my stang, i had a noise in the rear. Kinda made a hard to explain noise. I changed the wheel bearings and pinion bearings, the noise seemed to go away
drfister
May 3, 2018 10:38 PM
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Tyoung68
Aug 25, 2015 04:31 AM
kdryan
Aug 21, 2015 04:01 PM
