Malfunctioning engine temp gauge?
Old Mar 11, 2013 | 11:32 AM
3.8Cobra's Avatar
3.8Cobra
Default Malfunctioning engine temp gauge?
In my 1995 v6, the temp gauge as been reading way off. Even if I drive the car for 15-20mins it still reads cold, then every once in awhile the gauge will jump into the red zone. As soon as I turn the car off, it goes right back to reading cold again. I just topped off the coolant fluids last night and it seemed alright, but this morning it started doing it again. Would this be the enduing unit? Or what?
Thanks!
Old Mar 11, 2013 | 11:34 AM
LilRoush's Avatar
LilRoush
Is it really getting that hot?
When is it jumping to the red? While sitting still? While driving?
Old Mar 11, 2013 | 11:40 AM
3.8Cobra's Avatar
3.8Cobra
No, it doesn't get nearly that hot at all. And it's while i'm moving. Like, I was going home, the temp gauge jumped up so I pulled off and shut it off just to be safe. As soon as I restarted, the temp dropped right back down to cold. Not this was only like a 45 second break.
Old Mar 11, 2013 | 11:42 AM
3.8Cobra's Avatar
3.8Cobra
Plus I forgot to add that my heat wont work if I let my foot off the gas. If I have it pressed I have heat. Like, wtf? lol
Old Mar 11, 2013 | 10:05 PM
Mustang795's Avatar
Mustang795
I want to say something is wrong with your thermostat but this is a very weird problem. I know my car does normally take around 10 mins to heat up and I just put a new thermostat in it.
Old Mar 12, 2013 | 10:06 AM
BabyGT's Avatar
BabyGT
When you topped off your coolant did you have the heater on full heat and full fan? Sounds like you have an air bubble in your heater core. Make sure heat is on full blast when filling coolant to purge any bubbles.
Old Mar 12, 2013 | 11:40 AM
3.8Cobra's Avatar
3.8Cobra
That's how mine always was.
Did that exactly. I usually always keep it on full bast as it is since recently it's been like 20 degrees in the morning. And I next to never remember to shut it off, lol.
Old Mar 12, 2013 | 01:17 PM
Mustang795's Avatar
Mustang795
My guess is a bad thermostat that is either stuck open or closed. I would replace that it's only about $8. Than with the old thermostat boil some water and put it in it to see if it was actually working or not
Old Mar 12, 2013 | 02:05 PM
Daehawk's Avatar
Daehawk
Im also guessing air bubble. Heat not working is a sign of low coolant usually or a bubble. The added pressure from gas pedal down it allowing the core to get enough to work. A bad thermo could also cause it.
mtgldr
Feb 3, 2024 09:00 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
