Maf problem possibly
Old Mar 28, 2013 | 08:30 PM
colton46's Avatar
colton46
Default Maf problem possibly
In cold start the car has a abnormal idol for about 5 min it's revs to about 2k stays there for a few moments the drops a little. Then when I take off the car is really sluggish and falls on its face on acceleration. Back fires pretty bad also when shifting down to slow down. I unplugged the maf to see if the car would act any different and it didn't at all. My next idea would be the spark coils and plugs and wires but when my car heats up to running temp it runs really well it's just cold it runs like the worst car ever
Old Apr 4, 2013 | 12:46 AM
sm0kethed0pe's Avatar
sm0kethed0pe
it should be something with the purge i believe . having the same problem and fixing it tomorrow let you know how it works out.
Old Apr 4, 2013 | 02:40 AM
petrock's Avatar
petrock
Unplugging the MAF only tells you part of the story. Try cleaning it and see if it helps. A bad temp sensor will also cause cold start/idle/drive problems. When the motor is cold and waiting for the O2 sensors to get warmed up, the computer uses the MAF & Temp sensors to calculate how much fuel to put into the motor. If either is bad or producing incorrect readings strange things will happen.
Good luck...
Old Apr 4, 2013 | 01:23 PM
colton46's Avatar
colton46
I cleaned the maf car runs better but the problem still there. Let me know what you find purge.
Old Apr 5, 2013 | 12:02 AM
Tyre86's Avatar
Tyre86
My car is doin the same thing and kinda jitters at 40mph especially if I'm not accelerating and just trying to hold 40
Old Apr 5, 2013 | 12:06 AM
sm0kethed0pe
purge fixed some of it but still not to where i want it to. trying tps tomorrow.
Tivo304
Aug 28, 2023 12:19 PM
StalkerGT
Sep 25, 2015 02:41 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
