Using key cannot lock passenger side door?
Old May 9, 2013 | 01:00 PM
helloWW's Avatar
helloWW
Default Using key cannot lock passenger side door?
Recently the remote stopped working, then I started to use key to lock my car. But I found it can only lock the driver side door, not the one on passenger's side. Which part should I work on?
Old May 9, 2013 | 01:58 PM
PNYXPRESS's Avatar
PNYXPRESS
there is no key lock on the p/s door, therefore you cant use the key to lock it. You have to either do it manually, use the switch or use the remote.
Old May 10, 2013 | 08:45 AM
musicbox's Avatar
musicbox
The remote, obviously. If it's too much of a hassel to manually unlock your driver side door and then hit the power unlock button, then get your remote fixed. You probably just need a new battery or need it reprogramed. Take it to a dealer or find a part or specialty store who can help you. If you just want to order another one, any part store usually can order one in for you. 4 or 5 buttons, and more than likely will be cheaper than ordering it from a dealer.
Old May 10, 2013 | 09:04 AM
helloWW's Avatar
helloWW
Oh, I thought I could lock both side once rotate the key in the keyhole...seems I have to manually lock it
Old May 10, 2013 | 09:05 AM
helloWW's Avatar
helloWW
thanks for the advice. Will fix the remote! I doubt the battery run out also.
Old May 10, 2013 | 09:28 AM
DRAGUL's Avatar
DRAGUL
Check E-bay there are always alot of them listed for sale. Programming is easy you can do it yourself. Instructions are in your owners manual.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
Mikett
Sep 12, 2015 10:52 PM
Sep 8, 2015 11:50 AM
tmdm
Sep 4, 2015 06:45 PM
amandahchase
Sep 3, 2015 10:09 AM
