95 heads on a 99 block
Bought a sn95 convertible it has low oil pressure when hot pick up a 99 short block can i use the 95 heads and intake on the 99 block if i use the 99 head bolts and gaskets or are there any other things i will need to switch over.
Thanks
Thanks
Thats a possiblity doing the split port but really need to know if the 95 heads will work on the 99 block. I thought you have to change alot of stuff for the split port also. Just really need to get the bottom end out before its junk.
The split port is easy provided you have the modified fuel rail. It only took my brother and i a few hours to do. What made it more difficult was the fact that I did the Windstar swap at the same time. So I had to re locate the IAC and a bunch of vac lines.
