ps pump screams
Old Jul 26, 2013 | 01:36 PM
uscriuzers's Avatar
uscriuzers
Default ps pump screams
The new ones uscruizers germany i have been messing with my 2003 for weeks now .ps pump replaced ,bled bled ,etc still screams steers fine . The fluid drops every other Night am i dumb,20yrs army mech.and cant fix my own car.also have a buyer in 4 days help!! Scotty
Old Jul 26, 2013 | 01:38 PM
dawson1112's Avatar
dawson1112
First thing you need to do is find out where the fluid is leaking from.
If you run them low on fluid for to long they will always whine.
Figure out where its leaking , fix it and replace the pump.
NOTE you will need a special tool to remove the pulley so you can acess the bolts that hold the pump on.
Old Jul 26, 2013 | 01:50 PM
uscriuzers's Avatar
uscriuzers
Thanks forreply ,forgot to add no leaks anywhere,,rack ,boots,hoses ,maybe still air,bled myself later with son.mustang garage hete said replace rack ???
Old Jul 26, 2013 | 01:55 PM
Derf00's Avatar
Derf00
Gentleman's Relish
How do the hoses look? A lot of times PS hoses don't leak but they ooze fluid. How much of a fluid drop are you looking at every couple days?
Old Jul 26, 2013 | 04:38 PM
uscriuzers's Avatar
uscriuzers
Hoses look fine ,fluid drop bottom of cold level ,just checked with runnig l/r small bubbles come to surface when held .thanks for help to all in advance scotty
Old Jul 26, 2013 | 04:43 PM
uscriuzers's Avatar
uscriuzers
Maybe press hose is clogged my son said it sounds like the pumpis trying to push fluid. Through to small thruway ???
Old Jul 29, 2013 | 09:45 AM
BabyGT's Avatar
BabyGT
What's your definition of screaming? Ford power steering pumps are known to be loud even if they are in good working order. Also there has to be a leak somewhere you aren't seeing if your losing fluid. You might just have air bubbles working out still. And the pump will make a racket until it has the proper fluid level in it.
Old Aug 5, 2013 | 09:58 AM
uscriuzers's Avatar
uscriuzers
Thanks for all the help ,sold car as is price was right .German didnot bother scream
jwog666
Dec 27, 2021 08:09 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Sixer4Life
Sep 28, 2015 07:05 AM
mrappe
Sep 26, 2015 10:16 AM
