split port swap
Old Dec 7, 2013 | 10:59 AM
speakerman86's Avatar
speakerman86
Default split port swap
I'm in the middle of a split port swap. Head and lower intake are already on the engine. I also ordered injector adapters from 5.0resto. What I need to know is if the pins on the on the coil packs are the same since I have to wire in the 2002 plug on my 95 harness. Has anyone tried to do this?
Old Dec 7, 2013 | 12:42 PM
speakerman86
Either that or can I leave the 95 coil pack in its stock location?
Old Dec 7, 2013 | 07:43 PM
warthogdriver's Avatar
warthogdriver
I left the stock 95 harness and just added some wire then soldered the connections.
Also...i added 99 injectors on to the 95 harness...same thing...just added the 99 connectors and solder.
I also did a how to on the fuel rail to if that helps any.
Old Dec 8, 2013 | 05:49 AM
speakerman86
So you used the 95 coil pack and just extended the plug to reach?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Dokilar
15
Oct 16, 2015 08:13 PM
Bokeo
Oct 10, 2015 08:28 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
