Lower front control arm torque specs needed 2002
Old 11-30-2015, 06:17 AM
Jeff Modica
Jeff Modica's Avatar
Default Lower front control arm torque specs needed 2002
I need torque specs for the Front control arm to the k-member, nut for ball joint to the spindle, sway bar link with polyurethane bushings (if that makes a difference), reckon Pinion (the two bold in the front (where you would put offset bushings if my car were lowered), outer tie rod. Thank you!!
Jeff Modica is offline
69mach1377
12-10-2015 01:33 AM
Maine-iac
12-03-2015 04:34 PM
Urambo Tauro
12-01-2015 11:17 AM
Urambo Tauro
12-01-2015 11:16 AM
Jeff Modica
Suspension
11-30-2015 12:08 PM
Quick Reply: Lower front control arm torque specs needed 2002
