CEL problems
Old Mar 9, 2016 | 06:29 AM
Tomkat101's Avatar
Tomkat101
Default CEL problems
Good morning or evening to all haha! I have ran into a problem and I know you fine folks can help me out with it. CEL came on about a couple of weeks ago and code read misfire on #1 and #5. Long story short I replaced spark plugs(verified that it is sparking), wires, injectors, ignition coil, crankshaft position sensor and cleaned the MAF, IAC, and throttle body. When I test drive it, it seems to shake around 70mph and any rpm higher than 2000. I'm kinda stuck at this point. I was thinking about changing the camshaft synchronizer but would that do anything for the misfire CEL? 108,000 miles on it.
Old Mar 9, 2016 | 12:00 PM
lincolnshibuya's Avatar
lincolnshibuya
when you change the plugs did the CEL go away? if it's still there what's the code?
https://www.facebook.com/diyfordmustang
Old Mar 9, 2016 | 12:02 PM
Tomkat101's Avatar
Tomkat101
I cleared it and drive around a bit and it popped back up. Code is p301 and p0305. Thank you.
Old Mar 9, 2016 | 03:24 PM
lincolnshibuya
didn't fix the issues because the CEL came back.
you sure you didn't cross the wires? 1 and 5 are on the same coil. Or your ignition coil is bad.
Old Mar 10, 2016 | 06:34 AM
Tomkat101's Avatar
Tomkat101
Checked the wire orientation twice and it looks good got 123 on the top and 564 on the bottom of the coil. I installed a new ignition Coil and still received the CEL.
rocky321
Mar 17, 2016 04:14 PM
DreamerGT
Feb 4, 2016 08:03 PM
Gun Jam
Jan 16, 2016 08:19 PM
mjgalvan23
Dec 25, 2015 09:43 AM
