Fuel dilivery Problem
So my mustang was running great until one day is stopped working so I replaced the fuel pump and then there was no fuel dilivery on the rails no more and then I put the key in the on position so I could hear the humming noise from the pump however there was none and now I am in a dead end I don't know what to and my mustang has 24k miles on the clock.
Well hopefully you checked the battery.... but other than that you could've simply gotten a bad fuel pump. There could, however, either be a problem with the wiring that hooks up to the fuel pump assembly or with a wire inside the assembly. If you only replaced the pump and put it in the old assembly, the wiring in the assembly could've gone bad. If you replaced the entire assembly, it could be the outside wire as I said before.
Jarrod@latemodel
LatemodelRestoration.com
02-22-2013 08:38 AM
98gt_runner
05-24-2008 01:52 AM
JJfox
07-25-2007 12:53 PM
1BADASSLX
05-01-2006 04:55 PM
