front strut
Old Oct 29, 2005 | 04:30 AM
Autobadges.com's Avatar
Autobadges.com
Banned
Default RE: front strut
yes slightly i believe
Old Oct 29, 2005 | 07:07 PM
jj84756's Avatar
jj84756
i haven't decided if i want to go with the ford c springs or the mac. i want to lower my car close to 1.5, but if it was only like 1.4 or something that would be fine. would i need to get cc plates for that right off the bat, or could i wait a little bit?
Old Oct 29, 2005 | 07:31 PM
HRnB's Avatar
HRnB
Administrator
I think I remember if you don't go more then 1.5" you can adjust your "toe out" with the stock adjusters. I went 2" and I need them. Now that I have a 2" drop, I'd never gohigher. It looks f**king awesom.
Old Oct 29, 2005 | 07:34 PM
Autobadges.com
Banned
well your front tires will be like this when you lower it about 1.5" / \ so they are going to wear out UNevenly..meaning the OUTSIDE of the tires will have all the pressure and wear out there...and the middle will be like new.
If you are going to lower it...PERSONALLY I would save the time and hassle and do the following all together.
Lowering Springs
Shocks and Struts
Castor Camber Plates
When you lower it...the ride quality lessens so the shocks and struts are a real must...b/c on a bump you will hit harder than you think. And the CC plates make everything balance out. When installation springs the shocks and struts are LITERALLY like 6 inches away and you have to take it all out to do swaps so its killing two birds with one stone!
meaning when you swap out shocks and structs you have to pull off your stock springs to get to them....well when they do that....they merely up the NEW springs back in instead of the stock ones...BAM! then just align with cc plates.
ps we can get it all for you
Old Oct 29, 2005 | 07:48 PM
HRnB's Avatar
HRnB
Administrator
Good advise ^^^^^^
I didn't get new struts and I'll have to pull them back out now. I didn't think I'd need them for only 2", but now my shock center point is off and it does effect the ride quite a bit. C/C plates are easy though.
Old Oct 29, 2005 | 08:16 PM
Autobadges.com
Banned
Old Oct 29, 2005 | 10:00 PM
jj84756's Avatar
jj84756
ah to many choices. what if i just got ford c-springs, and bought the c/c plates a few months later? you think that would be ok?
Old Oct 29, 2005 | 10:03 PM
HRnB's Avatar
HRnB
Administrator
ORIGINAL: jj84756
Yes, but it will wear the inside edge of you tires faster.
Old Oct 29, 2005 | 10:28 PM
jj84756's Avatar
jj84756
do you think it would wear real bad in that months period? are the c/c plates something i can install, or something i need to have done?
Old Oct 29, 2005 | 11:24 PM
03YellowPony's Avatar
03YellowPony
ORIGINAL: jj84756
From what I read here, as long as you don't go lower that 1.5", you really don't need them. I went 1.5" lower on my fronts, and the alignment came out great.
