quick help
Old Nov 28, 2005 | 05:43 PM
jj84756's Avatar
jj84756
Default quick help
ok i am trying to remove the stripe at the bottom of the door and rocker, what is the best way to do that?? i got one piece off by picking and then pulling, but the rest is being really difficult.
Old Nov 28, 2005 | 05:46 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: quick help
how old is the stuff? The longer it's been on there, the harder it will be to remove. You can do a heat gun if it's really old or a hair dryer if it's newer. Just take your time with it. If you can, find some PLASTIC razor blades, I used those once to take off some really old pinstriping and it works awesome with a heatgun!
Old Nov 28, 2005 | 05:54 PM
justinlm24's Avatar
justinlm24
There is some kind of decal remover made for cars that will take it right off. I used it on an old S-10 I used to have. I can't recall the name, or if they still make it as this was 9 years ago. But if you can find it it works great. I used it to take the pinstripe off my S-10. Let it sit on for about 30 min then it peeled right off.....Best I can tell ya....Good luck.
Old Nov 28, 2005 | 06:35 PM
jj84756's Avatar
jj84756
thanks guys. it took me 20 minutes to do the 6 inch stuff on the front fender without anything, and took me 30 minutes to do the rest of the car with a hair dryer.
Old Nov 28, 2005 | 06:37 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Sweet!
Old Nov 28, 2005 | 07:07 PM
jj84756's Avatar
jj84756
yeah it looks good. i have to do some wet sanding though, cause on the passenger side ride before the rear wheel it was paing, and there is somewhat of a paint stripe. rather than that the driver side looks good.
Old Nov 28, 2005 | 07:14 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: jj84756
Is the paint of a slightly different tint in that one spot? That's normal since the paint underneath the sticker was never exposed to the sun directly. Wet sanding won't do any good. A UV light might fix that a bit. Also, any glue left behind, I would use a clay bar to remove it.
Old Nov 28, 2005 | 07:21 PM
jj84756's Avatar
jj84756
no it was repainted, and someone painted up to the stripe, so now there is a like where the old paint meets the new, so i am going to wet sand it so it is even.
Old Nov 28, 2005 | 07:37 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Ooohh, okay. If you're wet sanding be sure to use a VERY fine grit like 2000 or even 2500, then a rubbing compound, then polishing compound.
Edit, and there's no such thing as too much water.
Old Nov 28, 2005 | 08:13 PM
jj84756's Avatar
jj84756
wht sort of rubbing compound?? i just ordered 2000 grit, cause thats what my friend at the bodyshop said. also what sort of buffing compound?? i want it to come out the best that it can.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
svfetter
Oct 5, 2015 11:39 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Sep 25, 2015 06:30 PM
