Brakes
Feb 25, 2006 | 05:33 PM
RE: Brakes
well the cheaper faster way is not always the BEST way Harvey
RE: Brakes
What do teflon tape and pipe dope do
Feb 25, 2006 | 05:34 PM
RE: Brakes
its a thin white tape that wraps around the threads of the bolts/screws so when you install them they seal better
Feb 25, 2006 | 05:42 PM
RE: Brakes
Quote:
ORIGINAL: Autobadges.com
True, but if you're careful, you can reform the threads, and make it seal. I've done it a few times. But that always leaves the option of either replacing the entire line, or splicing in a new end.
Feb 25, 2006 | 05:43 PM
RE: Brakes
Quote:
ORIGINAL: ByPopularDemand
DO NOT use BOTH. It's an either or situation.
Feb 25, 2006 | 06:00 PM
RE: Brakes
Which one works better
Feb 25, 2006 | 06:39 PM
RE: Brakes
Try the teflon tape first. And TRY to get it to screw in correctly. BE CAREFUL tho. You do NOT want to strip the threads on the radiator.
Feb 25, 2006 | 06:47 PM
RE: Brakes
And it will seal. If I accidentally stripped the radiator threads I would need a new one huh.
Feb 25, 2006 | 06:48 PM
RE: Brakes
YUP!
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
