Wheel question
Old May 30, 2007 | 08:13 PM
mustanginexile's Avatar
mustanginexile
Default RE: Wheel question
i got them off of craigs list. a lot of these are out there at good prices. at first i was going to buy these from ebay:
http://cgi.ebay.com/ebaymotors/94-04...QQcmdZViewItem
Old May 30, 2007 | 10:33 PM
v6stang07's Avatar
v6stang07
they will but the offset is all wrong and like mustanginexile u may have some rubbin issues, plus they will probably looked tucked in the fender well
Old Jun 1, 2007 | 05:20 AM
EZimens's Avatar
EZimens
thanks for the feedback guys. i bought rims last night. Bullitt Anthracite. Mustanginexile, where did u get ur spacers?, just so i know in case i have the same problem
Old Jun 1, 2007 | 10:19 AM
mustanginexile
for the fronts not to rub i got them at a local parts store (Murray's Auto). You can get them anywhere. I went with 5/8" but non-hubcetric (spacer only). i dont recommend this for a permanent solution as it reduces the size of your studs which can cause them to snap. i put them on temporarily until i can get smaller tires. make sure you have 3/4" of bolt left after you put the spacer on.
to bring the rears to the fender instead of being tucked in i got 1.25" hubcentric spacers off ebay which can be a permanent solution:
http://cgi.ebay.com/ebaymotors/WHEEL...QQcmdZViewItem
Old Jun 1, 2007 | 02:55 PM
v6stang07's Avatar
v6stang07
yes if it is a permanent thing, make sure u get hubcentric spacers all around
Old Jun 2, 2007 | 08:04 PM
EZimens's Avatar
EZimens
what would u recommend for a permanent solution on the front?
Old Jun 2, 2007 | 08:23 PM
v6stang07's Avatar
v6stang07
really once u spend 100-150 on spacers u will be right at about the price of some take-off gt bullitts that have the correct offsett but hubcentric spacers would work fine for long term i would just periodically check them to make sure they are tight, also put loktite on the spacers
Old Jun 3, 2007 | 03:10 AM
lazypony's Avatar
lazypony
I think American Muscle and Stangmodshave some spacers if you're looking.
Old Jun 20, 2007 | 04:45 AM
EZimens's Avatar
EZimens
Got the rims on. they look awesome. didnt need spacers except to bring the rears out a lil bit. rubbing only occurrs when i have the wheel turned to the max and i never turn that hard so for now they are all good. thanks for the advice
Tivo304
Aug 28, 2023 12:19 PM
Luke9222
Oct 22, 2015 11:55 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
