A/C dripping
Old Sep 3, 2007 | 02:28 PM
StangBoy89's Avatar
StangBoy89
Default A/C dripping
Ok so I recently found out that I have my ac fluid dripping down onto my exhaust manifold, is that a bad thing or does it matter since the manifold is so hot it just evaporates??
Old Sep 3, 2007 | 02:33 PM
Nick4.6's Avatar
Nick4.6
I ♥ Acer
Default RE: A/C dripping
Thats totally normal. No need to worry.
Old Sep 3, 2007 | 03:00 PM
Daytripper540's Avatar
Daytripper540
In the long run it may cause an exhaust leak right there and you will have to either get new headers, or just get it welded up... but there is nothing you can do to prevent it really.
Old Sep 3, 2007 | 05:56 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Mine does the same thing and right now you shuldnt worry about it. Over time you might have a leak that you can either replace the headers, or weld them like Daytripper said.
Matt
Old Sep 3, 2007 | 07:11 PM
StangBoy89's Avatar
StangBoy89
Well actually i just fixed it earlier i found a little pipe that fits in the hole perfectly and it goes down past the manifold and onto the ground
Old Sep 3, 2007 | 07:19 PM
Daytripper540
You're not worried that that thing is going to fly out and take out someone's eye?
Old Sep 3, 2007 | 07:25 PM
StangBoy89's Avatar
StangBoy89
haha no not really worried, its pretty stuck in there and its not like a metal pipe or anything
Old Sep 3, 2007 | 07:26 PM
Xemeth's Avatar
Xemeth
Wow... SOOOO much bad info in this thread.
It's not A/C fluid. It's just water. Condensation. Hot air on the cold compressor makes condensation. It's not gonna crack the exhaust manifold. They'll do that on their own.
It's not A/C fluid. You'd know if your car was leaking freon. lmao
Old Sep 3, 2007 | 07:46 PM
johnt2k7's Avatar
johnt2k7
ford has a TSB out on that and actualy has a kit with a ford part number that comes with new pip and istruction on how to fix the cracks and a shield that actualy catches the water and runs it down and drops it onto the ground so it doesnt drip on the header and mid pipe flange
vargas
Jun 17, 2017 12:17 PM
69Volunteer
Sep 30, 2015 10:39 AM
SteelerNation82
Sep 16, 2015 07:11 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
HIS S-197
Aug 10, 2015 05:47 PM
