2 issues
Old Jan 11, 2008 | 11:24 AM
Narleycarley's Avatar
Narleycarley
Default 2 issues
Just bought a 95 v6 manual:
The heater/Airconditioning only blows through the defrost
The windshield wipers stay on constantly
Tried a new wiper/turnsignal switch= same thing
Tried a new HVAC panel = same thing
I'm thinkin the AC thing is vacuum related but not sure where to start or how to check
Old Jan 11, 2008 | 12:26 PM
STANG0446's Avatar
STANG0446
Default RE: 2 issues
I had the air blowing through the defrost problem with my 94 gt. It turned out to be a vacuum leak check all your hoses and vacuum valve.
Old Jan 11, 2008 | 01:13 PM
antwaan's Avatar
antwaan
i think i have that problem in my 96gt. all the sudden im not getting the upper vents to work. only the defrost and the floor ones. also, why did you post this in 4.6l tech? lol
Old Jan 11, 2008 | 06:27 PM
99_GT's Avatar
99_GT
The most commom cause of this is the hose that goes though the firewall. The flapper that directs air is vavume controlled. Check right at the firewall.
On the wipers you have a Wiper Control Module. Thiscontrols the wipers.
Old Jan 13, 2008 | 08:28 AM
Narleycarley
cuz same body style, and since i'm not dealing with motor stuff i just figured i'd get more response from the v8 dudes. since there are more around =)
Old Jan 17, 2008 | 08:04 PM
Narleycarley
ya.... the wiper module, $180 dealer only item, but that's what it was.... thankyou
Old Jan 17, 2008 | 08:17 PM
jthorn9's Avatar
jthorn9
The Godfather
As stated, vacume leak, and wiper module/motor.
Old Jan 17, 2008 | 08:24 PM
aode08's Avatar
aode08
I always say, $75 ftw, dealer diagnose, no throwing electrical parts.
Fords are tricky with electrical, if you are not experienced with a DVOM.
I recall a AC Module from hell in a Ford Taurus, only to find it was getting 12-14 volts, but not enough AMPS. Wiring harness FTW ON THAT ONE.[:'(]
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
