Sixxer chat
Old Jun 25, 2010 | 10:08 AM
  #2671
Shaunmac9128's Avatar
Shaunmac9128
Okay. I think I'm going to order that and a new set of headlights instead of the corbeau's, my stock headlights have seen much better days.
Old Jun 25, 2010 | 01:00 PM
  #2672
torchred02's Avatar
torchred02
i use Meguiar's Headlight and Clear Plastic Restoration Kit on mine. works awesome. a smoked set woyld look awesome too though.
did you get into ROTM Shaun?
Old Jun 25, 2010 | 01:07 PM
  #2673
Shaunmac9128
Haven't checked rotm. And call me crazy, I like the stock headlights. I've tried everything on mine but half the crap is on the inside, they are so beat up, a new pair for $80 on ebay isn't too bad.
Old Jun 25, 2010 | 02:33 PM
  #2674
sIx's Avatar
sIx
I don't recommend ebay lights, but maybe I just got lemon pair, but mine have gotten like a bunch of hairline cracks on the inside of the lenses :s
before they got replaced that is..
Old Jun 25, 2010 | 02:49 PM
  #2675
Shaunmac9128
I'll keep my stockers and give them a shot. Worst that happens is I put the stockers back in.
Old Jun 26, 2010 | 06:14 PM
  #2676
Fink's Avatar
Fink
New developments on the motor I picked up.
It says RWD on the flywheel side of the block. So that means its a 4.2L RWD block correct?
Im going to get an engine stand on monday or somethign so I can drain the oil and take the oil pan off.
Only ****ty part is that the engine came with nothing, no flywheel, crank pulley, water pump, etc.
I was thinking of fixing the head gasket(if that is the only problem) then mounting the M112 on top.
Old Jun 26, 2010 | 08:37 PM
  #2677
kman025's Avatar
kman025
i'm staying tuned for this.... should be a crazy set up when all is said and done
Old Jun 27, 2010 | 01:57 AM
  #2678
Fink's Avatar
Fink
Itll just be the run of the mill forged/full P&P 4.2/M112 combo. Nothing too special.
ugh... then ill have to build the trans.
Old Jun 27, 2010 | 06:16 AM
  #2679
Shaunmac9128
Run of the mil, however there aren't too many floating around here, and even elsewhere still not a ton. I would definitely throw the blower on there instead of the 3.8 but I'd put the motor in first and run it for a little just to make sure its all up to snuff.
Old Jun 27, 2010 | 08:40 AM
  #2680
LilRoush's Avatar
LilRoush
I agree. I swapped out my chrome stock headlights for the stock black housings from an '03.
