Cleaning the engine bay...
Old Nov 18, 2009 | 12:54 AM
rfcsoulja's Avatar
rfcsoulja
Would one need to cover up the sensor plugs (like the tps and IAC sensor)?
Old Nov 18, 2009 | 02:16 PM
hpwrestler220's Avatar
hpwrestler220
I washed my engine bay covering up the accessories such as the alternator and the fuse boxes and such and i ended up blowing more than 1 COP so i had to pay $90 and get 8 new ones... wasn't worth it IMO
go with good old elbow grease and a rag
this is just my personal experience and i will never wash an engine bay again. from now on i spray some solution on a rag and go at it...
Old Nov 20, 2009 | 10:26 AM
rfcsoulja's Avatar
rfcsoulja
^ Did you cover the coil pack?
Old Nov 20, 2009 | 11:29 AM
Shaunmac9128's Avatar
Shaunmac9128
When I worked at the dealership, every car we got it, we sprayed some hard core chemicals all over the engine and sprayed the whole things down and never had any problems, brand new cars and even during the cash for clunkers garbage. But I wouldn't do it on my own still.
Old Nov 20, 2009 | 06:53 PM
neo8222's Avatar
neo8222
i got a wand that plugs into my 60 gallon compressor set at 120PSI and it draws some purple power and water mix in from a hose and pressurizes it, blast it on scrub it and use water to spray it off. because it's not 1200 PSI from a pressure washer it doesn't cause any problems.
Old Nov 20, 2009 | 10:24 PM
98ga00's Avatar
98ga00
i didnt cover anything and sprayed my whole engine and nothing happened
Old Nov 21, 2009 | 03:44 PM
hpwrestler220
I had no prior knowledge about washing an engine bay, so my friend said he would do it with me. I helped (but i was reluctant because putting water onto an engine didnt seem logical to me). Anyway, we covered up the fuse boxes, the alternator, and the battery i believe. We did NOT cover the COPs. He used this same method the day before with his own 2000 GT. His car fired right up afterwards. Mine wasn't so lucky...
Either way, i will never spray water on my engine again. I ended up having to scrub it all anyway. I might as well grab a rag and some cleaner next time and save myself a possible headache.
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
zachary1988
Sep 4, 2015 03:04 PM
5.0 kevo
Sep 3, 2015 06:24 PM
