P0443 CEL code
Old Apr 25, 2011 | 09:00 AM
94v6's Avatar
94v6
Default P0443 CEL code
So I'm finally getting around to fixing my error codes. I replaced my cam position sensor but I'm not quite sure how to fix the P0443 code. I thought it was an O2 sensor but when I looked it up it says evap emission system purge control valve circuit.
Does anyone know how to fix this code?
Old May 12, 2011 | 02:56 PM
compdude97's Avatar
compdude97
I had that code, it can be several things, quickest and easiest would be the fuel cap. That didn't fix mine, it ended up being the Charcoal Canister Purge Solenoid. But that code can be a big pain to fix.
Old May 13, 2011 | 12:53 PM
94v6's Avatar
94v6
Yea, it's not my fuel cap :/ is the charcoal canister solenoid the same thing as the evap circuit solenoid? I also got some troubleshooting steps from a dealership and they mention the PCM a lot. I really hope It's not the PCM
Old Aug 17, 2011 | 10:22 AM
94v6's Avatar
94v6
Ok, so I've started looking at this again after just ignoring it for a while. I checked the purge valve resistance and it was around 78Ω so that is fine. What are other things to check for the P0443 code?
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
