Where is this cap located?
Hello,
This may be a stupid question.
But does the 2006 Mustangs have a separate radiator cap or is there only a coolant cap for the coolant overflow tank?
Just wondering b/c I was going to run a coolant leak test.
Thanks
Thanks
Coolant system pressure checks are basically the same. If you do not have a Radiator cap then YES, the pressure test cap would go on the Expansion tank. But: Always refer to the OEM Maintenance Manual to ensure it is done IAW their procedures.
Here is a You Tube Video :
Good Luck
