Drive shafts????
dude not to be a jerk but can you not see my STEEL drive shaft bent in f in half? sorry just had to vent!
ORIGINAL: thatstang
so do we have aluminum or not. I checked under the car but can't tell the difference. Maybe I can use some magnet or other means.
[IMG]local://upfiles/31806/354C6D0FFA354A9691DC3C64AED97F2D.jpg[/IMG]
ORIGINAL: afixer
ORIGINAL: thatstang
ORIGINAL: fazm
i think its actually about every 1 pound you loses in rotating weight, is equal to 2 lbs of regular weight. Neer heard claims as high as 5-7x. At most id say its like 3 lbs.
Before spending my money, I want to make sure that I'll get a benefit from a mod instead of following advertisement :-)
it will not work that way when lightening the drive shaft. It doesn't just take weight off of your car when you lighten ur driveshaft, it lowers the rotating mass of it , so it can spin easier with less power. 35 pounds off of a drive shaft would without a doubt show some decent power gains and shave off some time on the quarter.
here is a good link to explain difference in sprung/unsprung/hybrid weight.
http://victorylibrary.com/mopar/sprung-c.htm
ORIGINAL: afixer
my replacement shaft was an 06 model and it is also steel
How is it holding up? I notice that you push your car to the limit since you are boosted so you probably put more tension than the rest of us.
I read on the Visteon web site that new Slip-in-Tube driveshaft is 4 times stronger than regular so it should withstang higher loads. Not sure why your broke so easily. Oh wait, you did say that the u joint came loose and driveshaft banged against undercaridge.
Can we get regular aluminum driveshaft and still preserve integrity of Slip-in-Tube?
Sep 8, 2015 11:50 AM
