N/A POWER
yeah, 210hp out of a 4.0l engine is actually pathetic compared to the japanese cars running that infamous (at least infamous to american car makers) 3.5l engine that the 350z and g35 have (and i think skyline maybe?)
very dissapinted in ford when it comes to this one.... [
you get what you pay for $22,000 gets you the name mustang, new body style, 4.0L SOHC. If your not happy with what FORD has done, then use your own money to make it faster. Oh, and say our v6 stang was as fast as say a 350Z, guess what. Your insruance rates would be as high as if you had gotten a GT so you have to look at the whole picture.
ORIGINAL: Trill Gear Head
an intercooler just cools the ambiant air, detonation occurs when the air is hot and compression alone ignites the combustion process before the spark, kinda like pre-iignition.. colder air allows you stuff more boost in the CH because it will take that much more for the air to compress to the temperature where ignition happens.. also cold air is smaller in size (if you were to measure air) and you can get more in the CH relative to the air's density in the CH... 6psi hot = density A, 9psi cold= denisity A... just for example
It goes back to the belief that if Ford put a super-duper V6 or even straight-six in the Mustang that was equal to or better than an import six cylinder, then why would anyone buy a GT?
Having said that, I believe that the 4.0 can put out about 230-250 horsepower at the wheel, but it will need a hot cam and high flow heads in addition to CAI, Throttle-Body, Exhaust and Tune. I would also say running bigger injectors will help as long as you've got the fuel pump to match and don't forget beefing up the gearing.
Admit it, this would be a pretty bad-a$$ V6.
ORIGINAL: chrisc
BTW... I'll be avoiding cams and such... A lot of work ($$$)... especially the passenger side cam... hard to get a good tune.. I don't want to risk screwing up the "Streetablity" of my car...
ORIGINAL: chrisc
ORIGINAL: scrming
While they may make more HP... they tend to LACK in the Torque department! You need displacement for Torque... And the 4.0L does a really descent job making Torque... Torque is what pushes your butt in the seat! LOL!
ORIGINAL: chrisc
