crank pulley alternative
it would be a pain in teh *** to remove the AC system, IMO its not worth it.. a lot of labour would be involved.. and ill tell you it will be expensive
and it cant be just a "AC delete kit" theres no such thing if there was, it would probobly be just a smaller belt to make up for the lack of pulley
if you really want to do it
1 get someone ODP approved
2depressureize the system and remove coolant
3remove lines to compressor
4remve lines from the condensor
5chuck line from compressor to condensor
6romove and chuck condensor
7remvoe the receiver dryer
8remove dash
9remove remove lines from evaporator
10 remove and chuck evaporator
11 feed line from condensor to evaporator through firewall, chuck it
12feed line from evaporator to condensor through firewall, chuck it
13apply appropriate size belt, and in the direction that the pullies would still be spinning their appropriate direction (lack of pully can really screwthigns up, certain pulleys and their functions are designed to spin one way)
14 replace dash
15 go for a spin
8remove dash
14 replace dash
15 go for a spin
Golfsito
Oct 6, 2015 11:02 AM
