Shift Kits
Just wondering if anyone knew if any companies made a shift kit for these automatic transmissions? I just find myself manually shifting 1-2-3-D a lot of times and want to make sure I'm not damaging anything?
Can't add a shift kit to our cars... it's all computer controlled! If you pick up an SCT X-Cal2 you will find that your shifting in greatly improved! Things like shifts points and shift firmness are all setup in the tune...
BTW... maually shifting should not be a problem because the computer is still controlling the shift! Even if you push the shifter from 1 to 2 or 2 to 1 the computer will NOT make the shift until it thinks it is safe to do...
I think the ratios and shift points of the five speed are about perfect. It was one of the first things that I noticed compared to our old 99 MUSTANG. That shifted late from first to second and only had four speeds.
ORIGINAL: djl0657
jwog666
Dec 27, 2021 08:09 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
