What is wrong with MMR CIA's
RE: What is wrong with MMR CIA's
scrming had one, and if you check his website he has dyno's and other info on them
i think he found a few more hp out of the c&l
the mmr intake is probably a pretty good one, but the c&l is a bit cheaper and gives a bit better gains
ok.. here is my opinion... if your going to do a CAI then you should get one that requires a tune... Yes, I had the MMR and it didn't require a tune but what we found was it made most of it's power gain by leaning the motor out... The C&L (which requires a tune) out performed the MMR on the dyno by a little bit.. but on the street the C&L definitely felt better... And I think a tuner should be everyone's 1st mod! So go for a C&L/X-Cal2 combo... LOL
i have an mmr too. i have lidios tune, but since mmr claims it doesnt need a tune, do you think he accounted for it? should i manually up the fuel percentage a bit? With the dual exhaust will it be running too lean now? OMG i wish i had a dyno shop around here!
I have the mmr CAI with the high flow tube, I noticed a little difference when I first installed it, I have since gotten the car tuned. With such a little difference in horsepower, you made the right choice going with the one that looked better for you.
ORIGINAL: justang05
Matt's 95 Stang
10-05-2015 07:16 AM
panic
09-10-2015 05:56 PM
