ATT FAZM or RYGEN or SCRM
ok...now its crunch time for me ... iuve asked this already but cantg find the thread.
IM will be purchasing the magnaflow tru duals but do i ned to get addititanal parts such as what ever these H or x or y pipes are....
also will it require me to get a tune..
Can i install this with out a shop.. ie common hand tools? like along the lines of jackstands and some hand tools.
also who do you know sell it shipped for under 500
RE: ATT FAZM or RYGEN or SCRM
It depends on what setup you are buying as to what you need. If you are just buying a set of mufflers you will need GT pipes or a shop to bend a drivers side pipe for you. You will also need the pieces that the hangars attach to from a ford dealer(or a shop can weld up the mufflers like I had my shop do). In the attached picture I did a quick scetch of the different types of exhaust. You'll notice how the stock exhaust has a "Y" intersection at the top. This is where the pipes come from the headers / cats. The pipes turn into a single pipe that goes back to the single muffler. The JBA dual setup you but includes pipes and an additional Y-pipe that splits back out to accomodate the dual mufflers. The custum setup uses either GT takeoff pipes or a second custom bent pipe for the driver side, along with some kind of crossover(an "H" crossover in the picture). You can buy either buy an "H" or "X" pipe, or have the shop fabricate an "H" pipe for you. Since you have FI, you will probably want the true duals instead of Y-pipes so that you get a better flow/more power.
[IMG]local://upfiles/31031/72AFC96A04494BE5B3927B6837FC533F.jpg[/IMG]
this is the magnaflow pic of our exhaust. do i have to buy a separate H pipe or do i ask the shop fab one up?..
[IMG]local://upfiles/33810/2E9C63BD08D74B35876143B46A0A04AE.gif[/IMG]
ORIGINAL: armycook1981
ok.. so just by the tru dual kit and install myself..
IS a tune required.. if i order next week and say 1 week to get here.. i would be almost another week before im heading to the dyno again to get my tune issue worked out... i dont want to pay 150 for them to install it if i can do it myself
rygenstormlocke
06-15-2006 12:46 AM
rygenstormlocke
04-08-2006 11:05 AM
