Bad things about Chargers
Old 07-01-2006, 06:53 PM
fazm
fazm's Avatar
Default RE: Bad things about Chargers
the turbo is also upgradeable to a intercooler at a later time. PM me for pricing.
fazm is offline
Old 07-01-2006, 07:05 PM
paulboy16
paulboy16's Avatar
thru my contacts i can get u the turbonater for 59.99 + tax
paulboy16 is offline
Old 07-01-2006, 07:12 PM
rygenstormlocke
rygenstormlocke's Avatar
ORIGINAL: v6stanggoddess
would it be stupid to get an x charger without a cold intake of some sort? That way you can blow cold air into the engine?
Depends on the amount of boost you are talking, at 7lbs of boost, you should be fine with the xcharger and its easy to stay under boost when you are driving around. I personally stay under boost 95% of the time, then at the track I open her up.
The turbo is probably the safest option, but it is generally more expensive unless you get a deal or group buy. The Vortechs are known for being reliable daily drivers, and at low boost with an IC, you should be just fine.
rygenstormlocke is offline
Old 07-01-2006, 08:24 PM
scrming
scrming's Avatar
ORIGINAL: petepete
Any F/Ican blow your engine but probably wont unless your on the gas all the time. SHould be stable for at least 50-100k miles. A turbo gives a little bit less stress. AT the same time a super charger is better do to no lag and a turbo takes extensive mods in order to install the setup. The biggest disadvantage of superchargers is also their defining characteristic: Because the crankshaft drives them, they must steal some of the engine's horsepower. A supercharger can consume as much as 20 percent of an engine's total power output. But because a supercharger can generate as much as 46 percent additional horsepower, most think the trade-off is worth it. An intercooler or charge air cooler is an additional component that looks something like a radiator, except air passes through the inside as well as the outside of the intercooler. The intake air passes through sealed passageways inside the cooler, while cooler air from outside is blown across fins by the engine cooling fan. The intercooler further increases the power of the engine by cooling the pressurized air coming out of the compressor before it goes into the engine. This means that if the turbocharger is operating at a boost of 7 psi, the intercooled system will put in 7 psi of cooler air, which is denser and contains more air molecules than warmer air.
Good info... just a couple of comments...
Turbo lag... not in the Powerhouse V6 turbo car! I certainly couldn't feel any lag! Rygen, can you comment on lag? I was only in the passenger seat so I'm not 100% sure...
Oh... and guess who got to test drive the Cherry 6T6 today??? LOL! YEP!!! The Cherry 6T6 is a TWIN TURBO! Let me tell you there was no LAG!!! LOL! Oh, gosh it was wild!!!
Oh.. and the Vortech aftercooler (intercooler) is an air-to-water intercooler...
The Cherry!
scrming is offline
Old 07-01-2006, 08:27 PM
fazm
fazm's Avatar
you &*^&*% lol
fazm is offline
Old 07-01-2006, 09:27 PM
rygenstormlocke
Yea, punk!!!!!!!!!! Man, what a car to get to drive. Wow. As for lag, I don't have any, the size of the turbo is appropriate to our size engine, so its ready pretty much immediately. As for the Cherry twin turbo, holy crap. That car is plain sick. We need more details!!!
Old 07-02-2006, 12:02 AM
scrming
scrming's Avatar
ORIGINAL: rygenstormlocke
Details are here: http://www.mrt-direct.com/Articles/MRT_6T6a.PDF
and more here: http://www.mrt-direct.com/photogalle...2005/Build.htm
BTW.. the hood looks much better in person... (MRT will be selling them very shortly!)
Now.. as far as my detail... OMG.. the power is right there when you step into it... no lag.. It is also incredibly smooth!! It starts pulling and just keep pulling!!! And when the blow-off values let loose... WHOOOOSH!! WHOOOSH!!! HOLY CRAP!!! If you time it right as you pull up to the car in the next lane you can pretty much scare the crap out of them... we sure got some very interesting looks!!! LOL!
So Scott will be bringing a number of cars to Norwalk next weekend.. not sure which... so perhaps you'll get to see the Cherry first hand! LOL!
scrming is offline
Old 07-02-2006, 12:54 AM
whatdaproblemis0
whatdaproblemis0's Avatar
im curious to what or who set up their turbo or which did they use. Whats the Dyno RWHP ?
whatdaproblemis0 is offline
Old 07-02-2006, 01:11 AM
paulboy16
paulboy16's Avatar
yah i was wondering too. there ISNT a twin turbo on the market yet, so how the **** did they get it? soooo annoying when u see all these rich guys with the **** before it even comes out. pisses the **** outa me
ORIGINAL: whatdaproblemis0
Old 07-02-2006, 01:14 AM
fazm
fazm's Avatar
they are the manufacturer of it! LOL
fazm is offline
Quick Reply: Bad things about Chargers
