Noise from trunck or back left side
I am hearing a noise which appears to be emanating from the trunck / back left side.... it almost sounds like something vibrating against metal at a fast rate. This usually takes place when I let the RPM drop low in 4th or 5th gear.... [:@] It is very annoying!!
Has anyone experienced or discover the source of the rattle?
Thank you.
Thank you.
i think i read a while back that on some cars, ford missed a screw in the back left in some part of the trunk. its just an annoyance, you dont need to worry about your rear axle falling out or anything though
you should definitly take it back to your dealer and complain about it, they will fix it for free. in the next few months you may find a few more quirks with your car because ford was a bit sloppy, but they can all be repaired at the dealer.
ORIGINAL: chrisc
Let the rpm drop how low in 4th and 5th?
sorry If I am not explaining it quite right.
ORIGINAL: BlueStang6
One quick check - did you make sure your jack is planted securely and your spare tire is bolted down tight?
BTW that spare wheel sure looks sexy......
I hope I never have to use it LOL
Lizzy Date 7/22/2006 7:23:37 PM
Thanks I tried that, everything is secure.
BTW that spare wheel sure looks sexy...... I hope I never have to use it LOL
