Need some help with mods
Old Oct 14, 2006 | 12:02 AM
1bad197's Avatar
1bad197
Default Need some help with mods
Hey guys I have had my 06 for about a year now and ive done some mods... but im runnin out of ideas. I did a 75mm throttle body, a custom intake, 19" axis wheels and, and this month im workin on getting custom dual side exhaust. what are some new mods i could do that will increase my performance, but not sacrifice my warrantee... could I do a tuner and set it back to stock if i had a problem??? thanks for the help...
Old Oct 14, 2006 | 12:16 AM
scrming's Avatar
scrming
Default RE: Need some help with mods
ORIGINAL: 1bad197
Yes, you can get a tuner... like you said just put the car back to stock for service...
Performancewise I would say an limited slip differntial and gears!
Old Oct 14, 2006 | 12:17 AM
torchred05V6mustang's Avatar
torchred05V6mustang
+1 ^
Old Oct 14, 2006 | 01:02 AM
jericho73's Avatar
jericho73
ORIGINAL: 1bad197
Not hating or anything, but if you're worried about performance my recamendation is to ditch the 19's.
Old Oct 14, 2006 | 06:05 PM
1bad197's Avatar
1bad197
well i havent put the 19's on yet... got them for 200 and refineshed the clear coat... so i just have them... but yea im lookin at gettin somthin alittle smaller...
and if i get the tuner and flash it back to stock before a service they cant void my warrantee???
Old Oct 14, 2006 | 06:06 PM
1bad197's Avatar
1bad197
and do you guys kno if any1 is coming out wit a intake maifold any time soon???
Old Oct 14, 2006 | 10:40 PM
scrming's Avatar
scrming
ORIGINAL: 1bad197
If you flash the car back to stock, all they can tell is that the computer has been reset... A dead battery or a disconnected battery shows the same reset... so no, they can't void your warranty...
I posted this a while back... it's the 4.0 FAQ:
If you flash your car can the dealership tell? Yes, they can... No, they can't.... The debate has raged on long enough!!!
Here is the answer I got back from my sources inside of Ford engineering... I even had multiple sources confirm this... I'm sure someone is going to disagree with me... however I basically went to the horse's mouth on this one...
As it stands TODAY, all the dealership can tell is the last time the computer has been reset. Notice I said reset, not reflashed. Yes, reflashing does set this reset "date". But guess what... so does disconnecting the battery! LOL! So the dealership has no way of know what caused the reset... Simply tell them you left your lights on! LOL! Or in my case the bottle heaters! Ok, so maybe not the bottle heaters! LOL!
Now Ford does have a way to download the programming in the computer... if you did not reflash the car to stock then they will obviously see the differences and no you reflashed the car... however if you put the computer back to stock then all they will be able to tell is that the comptuer was reset... again... oops... i killed my battery... LOL!
Old Oct 14, 2006 | 10:45 PM
Rnstanger's Avatar
Rnstanger
Good info there
Old Oct 15, 2006 | 04:36 PM
1bad197's Avatar
1bad197
thanks for the info... its a big help.
would you do GT takeoff sway bars or aftermarket... is there gonna b a big diff btween aftermarket and gt takeoffs???
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
