rear axle went under water
RE: rear axle went under water
Best way to do that is to pull the diff cover off and jack up one side at at time. This will drain all the water out of the axle tubes. I would then fill the diff and drive it for a bit. Then change the gear lube one last time. This is to be on the safe side. Don't forget to clean and lube all your brake parts.
Kevin
Kevin
11-10-2015 11:39 AM
09-10-2015 08:39 PM
Dragonus18
09-09-2015 01:21 AM
