Automatic Question
Old Dec 10, 2006 | 03:57 AM
goffball5's Avatar
goffball5
Default Automatic Question
K so im an owner of an 05 V6 automatic....and i just noticed that when i switch between park and reverse..that little orange indictator thingy on the left isnt there...and when im in drive...the orange thingy says its in neutral...probably just something loose? any help or info on fix would be great. thanks in advance
Old Dec 10, 2006 | 12:25 PM
goffball5's Avatar
goffball5
Default RE: Automatic Question
anybody? please?
Old Dec 10, 2006 | 12:29 PM
AmericanICON's Avatar
AmericanICON
You're screwed... park it now!!
Just kidding.. Unfortunately, I don't think you'll get the magic answer of "here's the exact solution". You'll have to remove the center console cover and take a peak at it.
This is something that should be covered under warranty anyways; so perhaps the dealership could take a look.
I'm sure I'm not telling you anything that you didn't already think of.. good luck.
Old Dec 10, 2006 | 12:37 PM
goffball5's Avatar
goffball5
alrighty so basically i should just take it up to a dealership and have them take a look at it. hopefully they wont be gay about the exhaust/tune
Old Dec 10, 2006 | 05:18 PM
SparkYZ's Avatar
SparkYZ
If you're worried about the exhaust and tune (it SHOULDNT be an issue but you never know) you can look up the instructions for how to remove the center console and look yourself, or tune your car back to stock for the day its at the dealer
Old Dec 10, 2006 | 05:21 PM
fitbikeco's Avatar
fitbikeco
ya i have the same problem
the little orange indicator broke off and displays that its in park all the time
its not a big deal
as long as you can still shift the gears i wouldnot worry about it
unless your bothered by that kinda thing
Old Dec 12, 2006 | 10:00 PM
lmmmmm's Avatar
lmmmmm
unless your new exhaust is causing a tremendous amount of vibration which is causing the indicator to lose it position it should be covered. I doubt they can claim it came from anyother after market part unless you added something else to the drivetrain or transmission.
Old Dec 13, 2006 | 06:45 PM
enigma05's Avatar
enigma05
i just had a similar situation. my orange needle was stuck in neutral. which it didn't bother me. but as soon as it got cold here it got to where it wouldn't shift out of park after it had been sitting a while. i took it back to the dealership and they replaced my entire shifter. everything works fine now. hope this helps
mungodrums
Oct 7, 2015 04:01 AM
04stangman
Sep 17, 2015 01:45 PM
LivingInThePast
Sep 16, 2015 12:20 PM
nboost
Sep 16, 2015 05:35 AM
