New 07 Navigation Unit
Old 03-17-2007, 02:15 PM
nonstopred
nonstopred's Avatar
Default RE: New 07 Navigation Unit
does it have a cd changer still?
nonstopred is offline
Old 03-17-2007, 10:28 PM
bee bop
bee bop's Avatar
Yes and they say it lays MP3 better than the shaker. I havent tested it yet.
bee bop is offline
Old 03-18-2007, 02:40 AM
tomsa55
tomsa55's Avatar
bebop, let us know how it works... Maybe I only need to reinstall the shaker 500, let the tech get the build data from the oem radio, then install the nav radio and upload the build data. We didn't try it that way, and the opitional instructions from the ford tech manual says to recall the build data by vin. This gives them the type vehicle, year, model, date manuf, and equip installed. I'll have to check with the ford tech, but if your nav radio turns on with out an error msg, then your good to go. Check out what I posted about the gps antenna location, install in first, you'll see where you can reach up under the bottom of the top of the dash. Good luck, and let us know how it works.
tomsa55 is offline
Old 03-18-2007, 03:06 AM
goffball5
goffball5's Avatar
can u hookup ur ipod?
goffball5 is offline
Old 03-18-2007, 08:47 AM
HurricaneStang
HurricaneStang's Avatar
How much does Kevin sell the Nav. Kits for?
HurricaneStang is offline
Old 03-18-2007, 10:07 AM
Skoshi42
Skoshi42's Avatar
wow that is so nice!! too bad no GPS or Satellite radio here in Hawaii..... just APS (analog position system) aka Map!... haha.. they would really make a killing in Hawaii with satellite radio... tisk* tisk*
Skoshi42 is offline
Old 03-18-2007, 01:12 PM
bee bop
bee bop's Avatar
Here is a link to the instructions I posted on the mustang source http://forums.bradbarnett.net/showth...230&page=5. It is the last post. So far I haven't had any problems except for it freaking out ( nav system error) because it boesn't have any detailed information about my local streets, but once I get on the main Hwys it is fine. The surface streets show up on the map, but it just doesn't know anything about them. Hopefuly this will be corrected in the next DVD release (probably not. Thats what I get for Living in the boonies).The GPS picks up fine and tracks the car fairly accurately. I know you can paly MP3s in the palyer. They say it plays them better than the shakers, I haven't tested it yet. You can also connect the Sirrus system to it, it is a separate kit. It will work with the AUX port on the 07s. Kevin is looking in to the wiring requirements for this. It may not be possible to add this to the 05-06 with out a lot of work, we'll see. I also found a company that make an interface that will let you play DVD (Requires a separate DVD player)and has a provision for a backup Camera that will work on the Nav unit the link is in the above post. If anything comesup I will let you know. As far as the price Kevin doesn't like us posting prices on the boards, just send him an e-mail Clevparts@aol.com or give him a call 1-800-570-5554 ask for Kevin Casey.
bee bop is offline
Old 03-18-2007, 04:43 PM
nonstopred
nonstopred's Avatar
baddog671
07-26-2016 01:20 PM
kevsgt
10-09-2015 10:12 PM
lincolnshibuya
10-06-2015 08:45 AM
jrrhd73must
10-02-2015 09:17 PM
folivier
10-02-2015 05:34 AM
Quick Reply: New 07 Navigation Unit
