ASP underdrive pulley
anyone have any experience with these ?
http://www.v6mustangstuff.com/05Engine.htm
It says it makes 12hp/16tq what do you think?
is this an easy install or would i need a shop to do it?
Thanks.
Thanks.
RE: ASP underdrive pulley
i have one and am pleased with it along with off road xpipe and cai you can definately tell its more than stock. its not like you bolted a supercharger on it by any means though, cant be sure about the torque/horsepower numbers. you will need an impact gun, crank pulley remover, and a 3/8 ratchet(or serpentine belt tool) to do it. if you have these tools or know someone that does should only take about 15-20 minutes
This is what Denny got from a pro: (Denny) ask whats the pros and cons of this pulley. (Scrming) anwser, well... the crank pulley is a lot more expensive... more of a hassle to install... and really only showed a minimal gain over the alternator pulley.. plus the recommended belt length for the crank pulley was to long and had a hard time finding a good fitting belt! I think you can install it yourshelf if you have or rent the tools for removing the pulley. (Denny's reply) I'll go with the ASP pulley. Thank you Scrming, Denny Carlton
I would also like to know what is the best UnderDrivePulley to put on my car ?
Best meaning
*Safest
*Most HP - TQ
Also i give up a 1 hp or 2 for Quality Product that's safe, I've herd alot of people have problems with UDP's i would like to hear from someone that has Expirence with this
Best meaning
*Safest
*Most HP - TQ
04, 2005, 40, asp, belt, drive, install, installation, installing, mustang, pulley, s197, underdrive, v6
