I don't use 5th gear
Old Jun 16, 2007 | 12:07 PM
Ken Rogers's Avatar
Ken Rogers
Default I don't use 5th gear
99% of my driving is between speeds of 40mph and 50mph, and 4th gear is perfect for this. As a general rule, I only go up to 5th in excess of 60mph (in fifth I get around 1800rpm at 60mph). ShouldI be gearing up at a lower speed than this?
Ken
Old Jun 16, 2007 | 12:59 PM
07 Stang's Avatar
07 Stang
Default RE: I don't use 5th gear
I usually put it in 5th when going over 50 mph. From what I've read, the lower gears you use the better gas mileage for you.
Old Jun 16, 2007 | 01:15 PM
Torch_Vert's Avatar
Torch_Vert
What you're doing is normal. Fifth is an overdrive gear for highway cruising. It's mostly there for mileage.
Old Jun 16, 2007 | 05:34 PM
Ken Rogers's Avatar
Ken Rogers
Thanks. As my general rule, I don't cruise at RPM's below 1500 (on level ground).
Old Jun 16, 2007 | 06:04 PM
sdsguy's Avatar
sdsguy
i generally cruise at 5th gear in 60. i use to do this in 4th but since my MRT drone is horrible in this gear, i've been using 5th. get much better mileage too.
Old Jun 16, 2007 | 06:44 PM
28HopUp's Avatar
28HopUp
MF Administrator
You could install 4.10's, then you'll use 5th gear more often!
Old Jun 16, 2007 | 08:05 PM
ricklmesa@cox.net's Avatar
ricklmesa@cox.net
I use 5th with 3:73's lol 45 puts it at 1500 rpm. 4th im a bit over 2000rpm I believe.
Old Jun 16, 2007 | 08:23 PM
LL88's Avatar
LL88
Isn't it bad for the car to upshift at low rpms and cruise at low rpms?
Nick Oliver
Oct 17, 2018 04:22 AM
musnicki
Sep 23, 2015 07:11 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
Sep 3, 2015 07:14 PM
5.0 kevo
Sep 3, 2015 06:24 PM
